Interchangable parts
npulvirenti
hi guys I\'m new to the forum and so far found heaps of info for my 1997 Subaru legacy gtb.
but i have a question which has probs been cover manytimes before but I\'m unable to find any, i wanted to know what parts are interchangeable from other models to my legacy like the forester imprezas and what year like the front anti roll bar off a 2005 impreza wrx, that kinda info. doesn\'t matter what just really would like other ppls tryed and tested methods or experience from what they have heared or seen.
ok.
so at the moment i need down pipes (with decat but this is going off subject)
thicker sway bars and links
as my car is a twin turbo could i use an fmic kit for say a wrx or sti if you understand what im babbling on about.
suspention front and rear.
same fit turbos (so i dont have to piss about)
boost controllers
brake calipers rotas
gear box and rear diff (maybe looking for longer ratio)
manifold and up pipe. like use the manifold and up pipe off a 2003 impreza wrx
rite heres the reason why,
love the car goes well just want to improve on small things like, i like that it has two turbos coz it means in town when u need a little bit of power the first turbos there from 2000rpm and if im giving it stick (getting my foot down) these a second turbo for the higher rpms (looking to get a bigger turbo for higher rpms).
the handling is good for what it is its been lowered like 30mill and i dont want to go any lower just want it a little more crisp and sharp.
reason im asken about iterchangeable parts is so i can pick up second hand parts and not break the bank (nagging mrs lol).
so like i said improving on the little things but not breaking the bank lol
Honestly the best things that you can do is convert to single turbo. Gearboxes and diffs basically anything will go in. Swaybars impreza front is good but rear will have to be for BG or BD only because of the spare wheel bay.
Again, go single and enjoy life
you can put a 6 speed in anything you just ned the correct driveshalf and usually matching diff and hubs and shalfs, and use the search and you should fine what you want. we are switching to a new forum today so you may not be able to find it for a few days
