WRX axles differences
7ishNZ
The R160 axle has 2 types of CV spline.. 1 long one with 2 diameters to fit the VLSD unit, the other side has a single diameter spline.
Does anyone know if the VLSD axles will fit the suretrac diff? Thanks.
From what Ive seen, the early BC/BF diff which has the stubs has a stepped stub one side and single diameter other side. The later style has 2 equal shafts slightly diff to the early one so must be a different type of lsd - clutch or something? Havent read too deep into it.
  • 4 weeks later...
After some research... The VLSD uses the stepped CV spline, the plated and suretrac ones have the same CV spline each side, the circlip is inside the diff. The good news.. VSd axles will work fine in the other diffs.
I have 2 vlsd diffs on the floor the axles dont fit in the other. V5/6 is same cv spline each side and not suretrac so would guess the later suretrac would be similar style. Early viscous axles sure as **** dont fit into V5/6 lsd's. Almost certain that the stepped stub axle profile in BC/BF is different to the cv axle in V1-4 GC/GF.
