01 Legacy EJ206 Rev D Boost Gauge
Theaos
Hey folks
wondering if anyone can help me, im trying to install a boost gauge in my Legacy and am having issues with which Vac line to T off. The revision D seems to be different to any of the other Subys that I have seen and there are 3 lines running into the manifold and im at a loss which one to go with as RH one goes directly to the BOV but already has a T for something else which I have no clue about and i would have to extend it to use, middle one hooks down and looks like a nightmare/impossible to use and the left one is solid line until nearly a foot away from the manifold which would be easy enough to use.
Anyone else successfully done this that can point me in the right direction?
The left one going into hard line must be the vac feed for the BBOD.
The middle one that hooks down the front will go to the purge control solenoid.
The right line for BOV is T'd into hose 10 (recirc hose from boost control solenoid).
Use the fuel pressure regulator vac hose, drivers side/rear of manifold.
