Anyone know my car?
geebuddy
Hi Jakob, car is going well has needed work to get it warrantable (tyres, brake rotors, mid-pipe replacement) but seems to be running well. Fixed the play in the steering, the wheel doesn't wiggle when cornering downhill now :)
I saw in some older posts some issues that you'd had with the car; would you mind telling me what work you did on it? Replaced the turbo?
http://clubsub.org.nz/forum/showthread.php?40364-My-subaru-subaru-d-where-too-now
http://clubsub.org.nz/forum/showthread.php?40940-WTD-TD04-Turbo&p=527156#post527156
Due to the banjo bolt oil filters I told you about (now removed) the turbo did need to be replaced. Thought it was worse than it was at the time, but a compression test showed the engine to be in good order, so a recon turbo was put on and it never ran better to be honest.
