Intake query
SpeedySub
Hi All
New to the site and to Subarus in general. This is my first Subaru, a 1998 250T. The question I have is I was having a little look around the engine bay and removed the airbox/Manifold? at the TB and there was quite a bit of oil in it (sorry didn't think to take pics). I know that the breather pipes connect to the airbox/manifold but I am a bit concerned that there was a reasonable amount (at least to me). It appeared to be a few mils in there. Is this common?
Also I have read that this airbox/manifold is there for low rpm torque, so I am assuming that if I remove this and put a pipe connection directly to this it will change the torque characteristics. I would rather have more torque than more horsepower at the moment, so it would be best to leave on?
And yes sorry for the long post - I have been told that I ramble on sometimes!
Edited by SpeedySub
Very common, especially with a higher km engine. It's just oil residue build up from engine blowby. Pull the pipes off and clean them out with carby cleaner/petrol. A can of Subaru upper cylinder cleaner with every oil change will help too.
Thanks, thats set my mind at ease a little. My car has done about 168,000k's so not sure if that is high milage for a Sub? I ended up giving it a clean out anyway just in case. I have read a few threads of people adding a catch can, so maybe might do that at some stage money permitting. I'm not so keen on having extra oil in the intake.
168 is pretty low considering it's age, my 2000 is about to tick over 220km. I wouldn't be too worried about a catch can, it might take another 50,000km for it to get that bad again.
The Subaru Upper Cylinder Cleaner is great stuff, it will clean all the residue/carbon build up from inside the intake manifold/cylinders etc and help it run a bit cleaner/smoother.
I did buy some Threebond cleaner over the weekend. Thats why I noticed the oil. Smoothed out the idling on the car and does seem to run a bit smoother.
