Permanent cigarette lighter?
FST4RD
Is there a way on a GC8 to make the cigarette lighter work all the time when the ignition is off?
Basically I have a battery drain somewhere, I'm almost 100% sure it's the alarm, but the alarm is working perfectly, so I'd rather not play with it incase I fudge it.
I bought a solar trickle charger that can either go straight to the battery or through the cigarette lighter, although I would assume it wouldnt work unless the lighter is going.
 evowrx said:
How quick does it drain bat? You would be far better off just starting the car for a couple of minutes every few nights.
If the battery is fully charged then it's lucky to last 2 days. Battery has been tested a few times in different ways and always come back 100%, it's not anything in the car, the only thing I haven't tested is the alarm since I'm not sure how to. Although since everything else came back fine I assume it's the alarm.
