Camshaft Identification INFO
kamineko
Work in progress, use this info at your own risk. Please donate pics or other useful information to help fill in the table. I should include head casting info in the future.
FRONT > means the > points to the cam pulley when reading the raised bumps, black dot is raised. 'R3' for example changes to 'L3' on the left hand side. R_ represents no number.
There are only 5 identification bands on the machined part of the cam shaft. Other bands further to the outside, non-machined part seem to designate the position of the cam e.g. Right/Intake.
[table=height: 30, class: border]
[tr][td]F[/td][td]R[/td][td]O[/td][td]N[/td][td]T[/td][td]»[/td][td]Cam[/td][td]Engine[/td][td]Type[/td][td]Year[/td][td]Model[/td][td]u[/td][td]b[/td][td]s[/td][td]Buckets[/td][td]u[/td][td]IN Valve[/td][td]b[/td][td].[/td][td]EX Valve[/td][td]o[/td][td]r[/td][td]Valve Springs[/td][td]g[/td][td].[/td][td]n[/td][td]verified[/td][td]z[/td][td]Intake[/td][td] [/td][td]Exhaust[/td][td]c[/td][td]Lift[/td][td]l[/td][td]Duration[/td][td]u[/td][td]Profile[/td][td]Part numbers[/td][td]s[/td][td]u[/td][td]b[/td][/tr]
[tr][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td].[/td][td]z[/td][td] [/td][td]c[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]Type[/td][td]Dia[/td][td]Mark[/td][td]Length[/td][td]Type[/td][td]Mark[/td][td]Length[/td][td]Type[/td][td]Paint[/td][td]Free length[/td][td]Tension[/td][td]o[/td][td]r[/td][td]g[/td][td]BTDC[/td][td]ABDC[/td][td]BBDC[/td][td]ATDC[/td][td]Intake[/td][td]Exhaust[/td][td]Intake[/td][td]Exhaust[/td][td]Source[/td][td]RH IN 13032-[/td][td]RH EX 13035-[/td][td]LH IN 13038-[/td][td]LH EX 13053-[/td][/tr]
[tr][td]o[/td][td]o[/td][td]o[/td][td]o[/td][td]●[/td][td]g[/td][td]R_[/td][td]EJ20G[/td][td]RS[/td][td]g[/td][td]BC[/td][td] [/td][td]c[/td][td]l[/td][td]HYD Rocker[/td][td]n/a[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]?[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][/tr]
[tr][td]o[/td][td]o[/td][td]o[/td][td]●[/td][td]●[/td][td]r[/td][td]R_[/td][td]EJ20G[/td][td]1st gen legacy?[/td][td]r[/td][td]BC[/td][td]z[/td][td] [/td][td]c[/td][td]HYD Rocker[/td][td]n/a[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td]?[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][/tr]
[tr][td]o[/td][td]o[/td][td]●[/td][td]o[/td][td]o[/td][td]o[/td][td]R2[/td][td]EJ20G[/td][td]WRX[/td][td]95 - 96[/td][td]GC8[/td][td]C1[/td][td].[/td][td]n[/td][td]HLA[/td][td]30mm[/td][td]z[/td][td]93.3[/td][td]solid[/td][td] [/td][td]93.6[/td][td]solid[/td][td]c[/td][td]39.8mm[/td][td]25kg[/td][td]l[/td][td]u[/td][td]b[/td][td]6[/td][td]56[/td][td]55[/td][td]11[/td][td]7.8[/td][td]7.8[/td][td]242[/td][td]246[/td][td]newsmook[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][/tr]
[tr][td]o[/td][td]o[/td][td]●[/td][td]o[/td][td]●[/td][td]b[/td][td]R3[/td][td]EJ20G[/td][td]WRX[/td][td]95 - 96[/td][td]GC8[/td][td]r[/td][td]g[/td][td].[/td][td]HLA[/td][td]30mm[/td][td]I252?[/td][td]93.7[/td][td]solid[/td][td]E283?[/td][td]94[/td][td]solid[/td][td]n[/td][td]39.8mm[/td][td]25kg[/td][td]z[/td][td] [/td][td]c[/td][td]6[/td][td]56[/td][td]55[/td][td]11[/td][td]7.8[/td][td]7.8[/td][td]242[/td][td]246[/td][td]newsmook[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][/tr]
[tr][td]●[/td][td]o[/td][td]●[/td][td]o[/td][td]●[/td][td]b[/td][td]R3[/td][td]EJ20G[/td][td]STI[/td][td]95 - 96[/td][td]GC8[/td][td]b[/td][td]V2[/td][td].[/td][td]light HLA[/td][td]30mm[/td][td]I252?[/td][td]93.7[/td][td]solid[/td][td]E283?[/td][td]94[/td][td]solid[/td][td]o[/td][td]39.8mm[/td][td]25kg[/td][td]EJ20GDW5PE[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][/tr]
[tr][td]●[/td][td]o[/td][td]●[/td][td]●[/td][td]●[/td][td].[/td][td]R3[/td][td]EJ20G[/td][td]STI RA[/td][td]95[/td][td]GC8[/td][td]C2[/td][td]V2[/td][td]g[/td][td]shim under[/td][td]30mm[/td][td]INKO[/td][td]104.7[/td][td]hollow[/td][td]EXKO[/td][td]105[/td][td]sodium filled[/td][td]Green[/td][td]49mm[/td][td]26kg[/td][td]EJ20GDW5PJ[/td][td]yes[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]242[/td][td]b[/td][td]s[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][/tr]
[tr][td]o[/td][td]o[/td][td]o[/td][td]o[/td][td]o[/td][td].[/td][td]R3[/td][td]EJ20D[/td][td]TS[/td][td]94[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td]HLA[/td][td]30mm[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]DOHC[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][/tr]
[tr][td]o[/td][td]o[/td][td]●[/td][td]o[/td][td]●[/td][td]b[/td][td]R3[/td][td]EJ20H[/td][td]GT[/td][td]94[/td][td]BG5[/td][td]A[/td][td]r[/td][td]g[/td][td]HLA[/td][td]30mm[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]Red[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][/tr]
[tr][td]o[/td][td]●[/td][td]o[/td][td]o[/td][td]o[/td][td]b[/td][td]R4[/td][td]EJ20G[/td][td]WRX[/td][td]97 - 98[/td][td]GF8[/td][td]D[/td][td]V3[/td][td]b[/td][td]shim over[/td][td]33mm?[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]WRX AT and Wagon [/td][td]l[/td][td]u[/td][td]8[/td][td]52[/td][td]52[/td][td]8[/td][td]8.1[/td][td]8.1[/td][td]240[/td][td]240[/td][td]newsmook[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][/tr]
[tr][td]o[/td][td]o[/td][td]●[/td][td]●[/td][td]o[/td][td]u[/td][td]R4[/td][td]EJ20K[/td][td]STI[/td][td]97 - 98[/td][td]GC8[/td][td]D[/td][td]V3[/td][td]o[/td][td]shim under[/td][td]33mm[/td][td]IH[/td][td]r[/td][td]hollow[/td][td]EH[/td][td]g[/td][td]sodium filled[/td][td]White[/td][td]56mm[/td][td]28kg[/td][td].[/td][td]n[/td][td]z[/td][td]10[/td][td]56[/td][td]56[/td][td]12[/td][td]8.2[/td][td]8.3[/td][td]246[/td][td]248[/td][td]newsmook[/td][td]AA390[/td][td]AA390[/td][td]AA390[/td][td]AA390[/td][/tr]
[tr][td]o[/td][td]o[/td][td]●[/td][td]●[/td][td]o[/td][td]n[/td][td]R4[/td][td]EJ20R[/td][td]GTB[/td][td]96[/td][td]BG5[/td][td]B[/td][td]c[/td][td]l[/td][td]shim over[/td][td]33mm[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td]10[/td][td]56[/td][td]56[/td][td]12[/td][td]8.2[/td][td]8.3[/td][td]246[/td][td]248[/td][td] [/td][td]AA390[/td][td]AA390[/td][td]AA390[/td][td]AA390[/td][/tr]
[tr][td]●[/td][td]o[/td][td]●[/td][td]o[/td][td]o[/td][td]z[/td][td]R4[/td][td]EJ20K[/td][td]STI[/td][td]98[/td][td]GC8[/td][td]E[/td][td]V4[/td][td]l[/td][td]shim under[/td][td]33mm[/td][td]u[/td][td]b[/td][td]hollow[/td][td]s[/td][td]u[/td][td]sodium filled[/td][td]b[/td][td]56mm[/td][td]28kg[/td][td].[/td][td]o[/td][td]r[/td][td]9[/td][td]53[/td][td]58[/td][td]10[/td][td]8[/td][td]8.3[/td][td]242[/td][td]248[/td][td]newsmook[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][/tr]
[tr][td]●[/td][td]●[/td][td]o[/td][td]●[/td][td]●[/td][td]n[/td][td]R_[/td][td]EJ207[/td][td]STI[/td][td]n[/td][td]GC8[/td][td]G[/td][td]V6[/td][td]l[/td][td]shim under[/td][td]u[/td][td]b[/td][td]s[/td][td]hollow[/td][td]u[/td][td]b[/td][td]sodium filled[/td][td].[/td][td]56mm[/td][td]28kg[/td][td]o[/td][td]r[/td][td]g[/td][td]9[/td][td]53[/td][td]58[/td][td]10[/td][td]8[/td][td]8.3[/td][td]242[/td][td]248[/td][td]newsmook[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][/tr]
[tr][td]●[/td][td]o[/td][td]o[/td][td]o[/td][td]●[/td][td]z[/td][td]R_[/td][td]EJ208[/td][td]GTB[/td][td]2000[/td][td]BH5[/td][td]B[/td][td]l[/td][td]u[/td][td]shim over[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][/tr]
[tr][td]o[/td][td]o[/td][td]o[/td][td]o[/td][td]●[/td][td]n[/td][td]R_[/td][td]EJ206[/td][td]GTB AT[/td][td]2001[/td][td]BH5[/td][td]D[/td][td]c[/td][td]l[/td][td]shim over[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][/tr]
[tr][td]o[/td][td]●[/td][td]o[/td][td]o[/td][td]o[/td][td].[/td][td]R_[/td][td]EJ205[/td][td]WRX [/td][td].[/td][td]GD[/td][td]A[/td][td]V7[/td][td]c[/td][td]solid shimless[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]o[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][td]z[/td][td] [/td][td]c[/td][td]l[/td][td]u[/td][td]b[/td][td]s[/td][td]u[/td][td]b[/td][td].[/td][td]r[/td][td]g[/td][td].[/td][td]n[/td][/tr]
[/table]
Edited by kamineko
