Engine Comparison
loonytooned
Hello all how are we.
I have a 1998 twin turbo gt legacy facelift version. I have piston slap and know its just a matter I time before I will be replacing the engine. What I would like to know is what engine or small block can I use for a replacement. I will reuse my heads etc but need to know what block I can use year etc . also would a 98 wrx block be compatible. all information would be grateful and thanks in advance.
98 doesnt help much BG or BH (gen 2 or 3 shape) s that was the 'crossover year'
mine lasted near 10 years with piston slap but yea not bad idea to plan...
now running a CDB with TT heads & my original intake & sensors
Any short block will work. But they all have different shaped pistons and differences in piston clearance to deck (CTD)at top dead centre (TDC).
So to change to another model short block will mean you need to measure piston dish, piston CTD and combustion chambers. Then get head gaskets to suit, to keep compression ratio at 8.5:1 to match what your ECU is tuned for.
