AC Idler Pulley/Tensioner Pulley Recon
Rosssub
I pulled into the servo last night to hear my AC tensioner pulley bearing screaming. I cut the belt and carried on. Today I've replaced the pulley bearing and reinstalled it.
Here's the AC idler or tensioner:
To adjust the belt loosen the 12mm locking nut, then wind the adjusting bolt in (tighten) or out. I've removed the 2x12mm mounting bolts so the tensioner bracket can be removed:
Disassembled:
I've used a 21mm socket and hammer to knock the old bearing out of the pulley:
Squealing bearing removed, I then went to my local engineering shop and brought a replacement bearing for $5.80. The bearing size is 40mm O/D x 17mm I/D x 12mm:
I've used a 1-3/16" socket and hammer to press the new bearing into the pulley. Anything that fits the bearing's outer race neatly will do fine:
Reconditioned AC tensioner back together:
Then reinstalled. Now I just need to buy a new AC rib belt and throw it on. I'm using Dayco P/N 4PK0890, (4 rib belt 890mm long).
An old pic showing both belt part numbers. Both 5-10mm longer than OEM length, still a perfect fit but a lot easier to get on and off when needed:
5PK0880 (5 rib belt 880mm long) - Alternator/PS belt
4PK0890 (4 rib belt 890mm long) - AC belt
