Need Advice
JayBee
My name is Jason and I have a 2008 S-GT and I'm thinking of changing my turbo from the stock one. I have a Garrett T04B74 that I had bought several years ago for a project build and never used it. Can the ej20 manage that turbo? If yes, what if anything, will i have to change? I already upgraded my exhaust to a cat back system and switched my top mount intercooler for a front mounted one and i also upgraded my fuel pump. This is my daily driver and I am not looking for any crazy power or anything but I would love a little quicker spool.
It's getting up there but the EJ20x/y should be fine. Some have gone higher without issue and others have ruined them with much less power.
None of the flanges will line up so you’ll need to modify your uppipe to suit the new flange plus your downpipe, comp side will be all wrong too so some customisation will be needed there too. Then just support brackets and oil/coolant supply
The stock turbo spool is about as good as you’ll ever get as it is a tiny twinscroll turbo, this will definitely be slower.
