boost lines and small black cannister in the front right
gtlegacy
heya,
Just putting my legacy rsb 97 back together
the 2 lines that come from the gaurd on the passenger side no.10 and no.23
ive asked a couple people and 1 said 10 and one said 23 so i dont know lol
also the b4 twin turbo diagram loaded up on the motor and turbo section says 23 to the turbo t to the primary actuator and 10 to the other is this right for the bd5 ?
also when i got my motor done it got a split rail which moved the charcoal canister lines so at the moment i have a line spare from the 3 (smaller than other 2) that go from fuel tank on the passenger side which connects to the intake manifold steel lines
and the other from the green purge valve line is also not there to fit it ?
i dont have a problem with fitting them up with some silicon line?
the problem i have is from the bottom of the cannister the line goes to a small sorta tee thing just behind it
(bolts under the airbox mounts) but the other section just clips to the chassis and looks kind of like a weird valve whats it for? and do i need it?
can i just use a joiner as i broke it removing the engine
u sure dude? as the there is only one and there are both for the primary side the length wont reach and i remember they both plugged in there i know one is the boost controller from the selonoid to bleed of pressure and the other is a pressure feed one or something
hey ok i have it going
the car is great and im running her in it has a vf20 and vf27(with the actuator stuff from the vf19 that was in it)
when the primary turbo is going it only goes to 8 psi is that right?
dont know what the secondary goes to because of run in
how would i know if that solenoid box thing is playing up? would it throw 65 or 66 ? any other tell tale signs?
knock sensor and afm have been replaced ands no codes since
