cooling problem
Hey Guys
Just got home from work tonight and found the car was over heating, opened the bonnet and found there was coolant sprayed all over the engine, this is on a 99 b4 legacy it was dark so couldn't really see if a hose had come loose or split. Has anyone had a similar problem?
Hope its not a major :(
Quite common for Suby's to split the end tanks on the radiator or the hoses. Usually the top hose or drivers side end tank as thats the hot side. If you can't find it once its cooled down, re-fill it with water, and leave it running till it warms up. Often you'll then find where a stream of water is coming out of it.
Same problem happened with my '99 B4 last month. Top of plastic radiator cowling's seam (hope that made sense) that connects to the top of radiator perished. You could fill the header tank with a hose, give the engine a rev and the water would pour out the top of the radiator. Had to get the AA to come tow it to my garage down the road as car was obviously undriveable. End result was radiator repair and re-flush etc costing $430. If i had expected the bill to be so high i would have contemplated purchasing a new alloy radiator off TradeMe for around the $300 mark and installing myself.
Hope this helps
thanks for the advice guys, just dropped it off at my local garage to check it out, hopefully its covered under the mechanical warranty $250 excess, hoping they pay out though ;)
