ABS LIGHT grrrr
!!!!!Model and year usually helps when posting!!!!
Anyway abs has diagnosis connector’s to get codes, let me know your model and I will step by step you
we can flash the code out of the abs control module...
I CAN POST IN HERE NOW yippee, any who, u still should have the code imbedded in the abs control module I would personally find out what code your abs system will flash just to be sure.
Couple ways to do this, so if you need help just ask, I’m a big fan of homemade Code Reading crap so I got a tip or to if you don’t have scanner handy
Could be nothing more than a flat battery. Did you have to jump start it?
You could have a look here... http://codes.rennacs.com/ABS-Brakes/Japanese-Korean/Subaru-ABS.php
There are a couple of likely models for that year, one has pipes going in the side of the abs unit and the other has the pipes in the top. Let us know which and we can tell you where the test connector is and how to extract the codes.
Ok, I think that this is the one for you....
There are instructions and a picture of an american model here... http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/abs-2E-diagnostics.gif
Then there is a list of trouble codes here... http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/absdiag.jpg
I suppose you already know it but, both those pictures can be enlarged by finding the clickable button at the bottom right of the photo. Just mouse around till the button lights up then click it.
If those terminals aren't there let me know and I'll post the other possibility.
