Pivot Speed Meter
predator
 Koom']
B106:11 or (B:11) is the wire you're after. From memory its purple.
Click on the thumbnail to enlarge.
[quote name='Hopai said:
I can install this in the Auckland area for the price of a cold beer!
Literally only takes a few minutes :)
Sorry mate I have to rob you of a potential cold beer but I got it working now ;)
Thanks for the info guys, I did some research after my first post here and managed to get it working in the end.
Note: The following information is for people who purchased their Meter overseas and do not have the JDM ECU diagram
The diagram below shows the ECU pinout from a EJ20G (GC8 A to C), what you need is the speed sensor pin which is pin number 40
From here, you simple cut the wire on pin 40 with reasonable distance so you can skin the insulation on both sides:
** Green wire from the Pivot meter goes to the ECU side
** White wire from the Pivot meter to the harness side
The rest of the instructions on the manual worked fine for me as they are generic and not vehicle specific so just follow those.
Hope this helps anyone else who runs into the same problem as I did, but agreed it is a very quick job if you know which wires are actually relevant to the job!
Your Pin 40 is the same as the B:11 I pointed out earlier and the chart I showed has both the early GC8 pinouts and English ;)
