McIntosh system
Probably been asked many times in the old forum but anyway, my front speakers are poked in my RSK.
Should I replace em or have em repaired??? I understand there may be issues with the McIntosh amp setup if I replace em....something about different ohms??? ...if so...may just be easier just to get em repaired...also what size will fit if I replace em? 6 inch or 6 and a half inch??
Cheers,
WIll.
you can use 4ohm speakers, if you unhook the tweeter. Both the speakers and tweets are 8-ohm, which actually gives the amp a 4ohm load.
If you get some good 2- or 3-ways, they'll sound better than the standard crappy paper cone speakers.
If you upgrade your headunit, you can bypass the factory amp altogether. I'm yet to do another write up on this. I'll have time tomorrow so I'll do it then.
