i have a 94 BC legacy sedan witch i brought not going, i was told that it needed a new fuel pump but i hard wired it and found it to be fine. im not getting power to the fuel pump motor even after changing the fuel-pump relay. when i hard wired the fuel pump i tried to start it up and found it has no spark.. the guy i got the car off said he was driving on a bumpy gravel road and it just turned off....
i cant figgure out what going on with it!!!! plz help me!!!
Check the codes...
my guess is code 11 might pop up, or you have a lose connection somewhere
You need to check you have power to the ecu. It could be that a plug has come loose going into the ecu, main relay, or a fuse has gone. There will be several live feeds into the ecu. Get a wiring diagram and check they all have power.
