WOF Fail on secondary turbo oil leak
I just failed WOF on secondary turbo oil leak and I'm just wondering if that is a legitimate reason? It's like a fire hazard or something? Just wanna check with you guys :)
Secondary turbo oil leak is normally from the drain hose as QuickGT mentioned
Easy as fix, remove the black box of death, the hose is very accessible, fit 2x hose clamps
Reassemble and clean leak area
Should be ALL good from here
