I just failed WOF on secondary turbo oil leak and I'm just wondering if that is a legitimate reason? It's like a fire hazard or something? Just wanna check with you guys :)
yes I had the same
basically any excess fluid leak is a fail
I went from vf18/19 combo to vf31/27 - all bolt on 'upgrade'
Ah really? So getting two bolt on turbos were cheaper than repairing the leak?
yup - un-rebuildable i was told
hit and miss whether you get a good one (or both if you are keen)
both mine were leaking so I replaced both
Secondary turbo oil leak is normally from the drain hose as QuickGT mentioned
Easy as fix, remove the black box of death, the hose is very accessible, fit 2x hose clamps
Reassemble and clean leak area
Should be ALL good from here
I presum you mean all over the IC
Can you post the pic's from the last forum when you did your starter again
