How do I change the stop light bulbs (outer ones) on a BH wagon?
Take the light assy out (should be 3 bolts around the tail panel and one partway up the inside guard).
Vola.
Whoever at Subaru decided to take the access panels in the boot out for easy bulb changing needs to be shot.
 SpotMe said:
Er, where do I find these bolts? Are they behind all the rear trim? Cos that looks like a pain in the arse to get out.
Yes they are... and Yes they are!
 boostin said:
They do it to prevent water leaks into the cabin. Pity they ****ed up with the garnishes on those.....
Haha too true.. but that being said, I've never had any leaks in my GC8's even after taking the lights in and out on many occasions and not replacing the sealant on them... Even then, it's nothing a bit of Selly's Instant Gasket can't fix!
I managed to get them off, it wasn't has hard as I was expecting.
Only problem I have now is the LED stop lights I've installed cause the ABS light to come on and disables the ABS entirely! So I've had to put one normal bulb back in for the moment until I come up with an alternative solution.
You've gotta laugh!
You need to run a resistor in parallel. An LED is an open circuit to the bulb monitor. I would check the resistance of the old bulb and fit a resistor that is slightly higher resistance than that.
