Beeping when brake pedal is pressed
nickmcgill
Hey team,
Just went to move my car up the drive tonight.
It started as per normal except when I put my foot on the brake it started making the beeping noise that normally only happens when it is in reverse.
( 2000 B4 AT )
Will beep if the park lights are on, same with the fog lights however with the fog lights the beep is quieter when the pedal is pressed.
Also trips a relay near the trans shifter and causes the dash lights / stereo lights etc to all dim.
I'm guessing its a short of some kind..
Any ideas ?
Interesting problem both of my BC5s have, that isnt immediately obvious, is the driver's side door switch being faulty and triggering the key-on-door-open beeper every time you make a right turn, so it could be related (I am not aware whether this fault occurs on BE/BH)
