When installing IEBC what to do with factory solenoid
cpt kernow
When installing IEBC what to do with factory solenoid?
If I unplug the factory cables the engine won't run (obviously). So the question is..
1/ Do I use a second solenoid with IEBC and just unplug hoses from original?
2/ Do I use a resistor in place of the original to trick ecu and then run IEBC to factory solenoid?
Ideas?
Chur
That's what i was thinking as a resistor might play with mapping and fuel ratios etc.
I've got a second solenoid to stick under the bonnet.
BTW it's a jay-car programmable one, so I'll keep you posted on the progress once installed. It's been in the desk drawer for 6 months. Now I've got a work car I can start playing with the foz again
 boostin said:
Why would the resistance change?
And its not a WOF thing either.
Spose not, it's just a coil with a bit of metal inside. I was thinking more of like a motor.
Thought it was wof things as the guys pulled up floor mats to check ecu cables for links/iebc's once before
 cpt kernow']
What wankers! Where was that at?
They are not allowed to "remove" anything in a wof check I believe and that would include lifting carpets,
also where the vac hoses goes,whether it has an aftermarket ECU or a Boost controller is none of their business and not part of a Wof check
Either take it someplace else or sit there and ask questions .... And then complain to the manager in writing....
They are being arses
