Quick q re: sti brake swap
Hey all, so I've gotten a set of sti 4-pots from what I assume is a v1 or v2 sti. Just wondering regarding the lines, on the sti lines there is a little clip thing that goes into a hole as part of the bit that bolts up to the caliper. The wrx ones don't have this. Am I right in assuming that that is just something to hold it there to make life easier or some such and I should ignore it? Or do I have to swap the lines...
 Tony said:
You're right, it just something to hold the line there. Your lines will work fine, so really just your choice if you can be bothered swapping lines... will work either way.
Yeah figured as much and just went ahead with it as nobody had replied :P nothing leaked out of the hole when I bled the calipers and I didn't end up in a wall on test drive so I assumed it was all good ;D. Cheers though
