boost drop!
hey my 00 b4 is running fine up to about 4 grand then the boost drops away to zero.. iv checked 2nd turb seems fine.. no noise or smoke out exhaust.. any help would b great cheers
1. Check that your vacum hoses are connected correctly to the EGV on the secondary turbo. Cant remember the numbers off the top of my head, but can look later if you need to know. If they are hooked up the wrong way round, you will get the exact symptom you've mentioned, with no CEL.
2. If you have a ZS sequential controller, this may need resetting. However a CEL normally accompanies this.
i dont think anything is hooked up wrong as it was running fine one day then the next morning it was like this. i have standard air filter so i dont think there is too much restriction... would the next thing be to get it checked for codes?
Just to clarify here, you mean it drops to 0 and Doesnt come back up?
Id stick it in diagnostic mode (connecting green plugs together) and seeing if the exhaust and intercooler actuators all move like they should.
i had this problem when my BBOD (black box of doom) crapped itself. i was getting no boost on secondary. i had to replace the BBOD cost about $100 from wreckers.
