testing a coil
dubbedup
Guest lan_killa
You can check the resistance of the primary winding, by putting the probes across the +ve and -ve terminals, will have to consult a manual to see what resistance you should see
Also you can check the secondary winding by putting one probe in where the HT lead goes in and the other on the +ve terminal, once again resistance should be in a manual
I will see what I can dig up for ranges for you
Also do you have a ballast resistor in there? Maybe its possible someone has put in a coil that doesnt require a ballast resistor and if youve already got a ballast resistor in there youll be getting a very weak spark
Guest lan_killa
Ok primary winding should be 0.4 - 0.6 Ohms, Secondary winding should be 5000 - 7200 Ohms.
Let me know what you get, and make sure youve removed the coil from the car when doing this as having leads still attached can alter your resistances
Guest lan_killa
Last coil i brought through repco was $80... Which shape L series do you have? I know my one didnt have the resistor, but I beleive the earlier ones did.
Also, if you do have the reisitor, chuck the multimeter across that while your at it, the resistor will have written on it what the resistance is
