The old Boost spike~ ish
R.D
A while after getting my car, i noticed sometimes when i stomp the pedal down to where it belongs, the boost jumps to around 18psi. It normally holds around 14psi~. untouched. But on occasion it jumps to around 18 and then slowly decreases, but doesnt really make it back to the usual 14. (it might in say 4th/5th gear, but when going that fast I generally dont study the gauges haha).
Its fairly stock, i think i read that bigger diameter pipes from the turbo can cause spikes? But mine is cat-back, so cant be that?
Im guessing it has to be a leak, cause it definitely doesn't go harder when it jumps to 18pound. I think id say a decrease in power, but if it was a leak somewhere, wouldn't it be happening nearly all of the time, if not always.
Wat do ya'll doctors suspect ??
Cheers!!
id say that your butt-o-meter is broken. if the guage is reading correct then 18psi is manifold pressure assuming you have it plumbed correctly, it wont have a leak... it will spike when the ambient temp is alot cooler than usual as in early morning.. what car is it?
the car below. v4 sti.
So what one must do to fix a butt-o-mete then :P
So if its not a leak, it actually is boostin 18 pounds of glory? That must be stretching the stock fuel set up? Why does it feel slower then?
if i was you, 1st thing would be to check any codes stored, then reset computer.. i believe v3 sti run around 17psi factory so v4 could be similar... i wouldnt be worried about it tho unless its detonating
