forester Phase1/2 or v3/4..v5/6
Guest itsgotgo
Guest itsgotgo
1 point in compression would not do it....I think,(could be wrong) :)
The afm still reads air flow=voltage to ecu fuel input.The ecu only dumps in the amount needed then advances or retards acordingly to octane and all that.(not nessacerally in that order)
I would think of the things that can affect fuelling....fuel reg reading vac incorrectly or stuck or a map sensor going flat out.
Or the injectors are not working right.
I have seen big daves foz before he upgraded and it was heavy on fuel then,running 14 psi. :)
high fuel comsuption :)
black smoke :)
fuel gauge goes to "E" too fast :)
Too many fuel stops on a road trip :)
AF ratios out of the normal range :)
petrol coming out the tail pipe :)
fouled out sparkplugs :)
