Alternators Whose been there?
Guest DVNT
As above has anymore pulled one apart?? any tricks to doing it or straight forward? i have one with a noisy bearing or bushes
Also are EJ18 and EJ20's the same? ie both have same round plug on the back and same amps? in case i can find one cheaper than the other
easy as, bearings are also easy, hardest thing is getting the front pully off if you need to get it off.
if you dont need to take off the pully. just undo the screws, and it will pull apart, you may need a screwdriver to pry it open at the beginning.
-smurff
the noise is coming from the back rather than the front, from memory bearings in the front brushes in the back?
Looks like you need to take the pully off to get the front cover off??
