Andy_Mac
Admin
Andy_Mac last won the day on March 7
Andy_Mac had the most liked content!
6 Followers
    Tauranga
Andy_Mac's Achievements
Like a Boss
Like a Boss (7/7)
2.2k
  1. Something rectangle that sits in the top 1/3rd of the vents would be cool, like a P3 gauge but with more specialised info available. Having DCCD there would be cool
  2. Can checked has them as part of their small can gauge or a module individually. Could probably just configure it to flash a section of the screen different colours as you approach the shift point too as another alternative.
  3. It’s generally worth getting a tune done just to get away from the factory one which is very emissions dependent so can be far from great on most Subaru’s. Not sure on VA’s but some of the Legacy’s could get noticeably better economy for cruising which helps a bunch for long trips An aftermarket intake and downpipe along with a tune will really wake it up and even with the on paper figure being not that much higher it can be way nicer to drive. The SI Drive stuff can usually be optimised a bit too so it acts more like separate maps rather than just pedal feel.
  4. Interesting. Had been talking to Niran and reading up on a few others having the same dilemma and they had all basically said you'd have to pay to have it sorted which could be big bucks to get sorted.
  5. Cool idea. Would like some sensors again but definitely need to be proper integrated ones rather than big lumps on the stems. Another one that is a heap more work but very needed is decoding DCCD stuff for the dash so an aftermarket one can display it. Seems a real pain for anyone wanting to go full digital with no way to show current mode/settings.
  6. Ahh yes it is too. I was thinking of the 4th gen Legacy’s where the upper is plastic
  7. Kinda like it. Would look nicer as a single piece that fully replaces the original flat one to have a more flush look.
  8. Have you seen how on the later cars they have both fed from the same reservoir? Haven't seen it myself but it gets talked about a lot on FB pages. Could get lucky and find that res fits straight on our brake master then just run the line down to the clutch however they do it from factory.
  9. That mopar way seems like a heap more effort. The Volvo should be just a matter of new supply and return lines then power. Some people even run it with no signal stuff working so it goes into a sort of limp mode and just runs a fixed percentage assist, something like 60-70% It would be interesting to see real world amp draws on the Volvo, I’d assume it’s usually quite low and only sees anything particularly high during full lock at crawling speeds where there’s probably enough grunt in the battery to negate the shortcoming for short bursts.
  10. Exact reason it peaked my interest. @Gripless the at should be pretty easy for a tuner to sort out then. Some form of feedback if it’s unhappy for some reason might be nice if it even does that but not really needed.
  11. You’d still need to be able to sniff out the data to get the ECU to understand it though, not hard for a shop I guess.
  12. Pretty sure there’s a factory alternator from a Tribecca that’s way bigger than any others but may still keep external dimensions which the track subie guys go to. There are some control modules out there to control them externally. One just has a GPS so at ultra low speeds it adds max assist then slowly tapers back with speed. Hooked onto an aftermarket ECU would be ideal but that’ll be a bit more effort and cost. https://www.servtronic.com/products/new-automatic-gps-volvo-c30-c70-s40-v50-power-steering-controller-kit?fbclid=IwZXh0bgNhZW0CMTEAAR2LGYst-5INecRFaTWGb47DWVpINB73zOkX7_Lb5wke4lu4be8Nx0988gw_aem_MnABhHFABHcxr9eD9n8aKw
  13. Have you seen the electric Volvo power steering pump people are trying these days. Not sure if there are any cert issues with it but it looks like a sweet option. Would mean the alt could get flipped the opposite way for a low running reverse manifold while still keeping AC
  14. What kind of k’s are you looking for? 32k is pretty steep unless its a GV sedan and super low k’s or heavily modified. 20-25k is about the point for a pre facelift GR with somewhere in the 150kkm + area Also EJ25’s aren't super terrible, probably better with an auto where it’s harder to thrash/shock them. The pistons are the main weak point that don't like the abuse or a crap tune
  15. Kinda an age thing but they do insure other vehicles that don't quite fit the standard daily driver criteria. Mines a 2010 but heavily modified and does barely 4kkm a year
  • Who's Online   0 Members, 0 Anonymous, 177 Guests (See full list)
