Ross
Subscribed Member-
Content count
18 -
8 NeutralAbout Ross
Rank
- Birthday 10/01/96
Location
Otaua
Occupation
Arborist
87 profile views
Only because I'm pedantic and it adds 5hp, as long as the applied model is the same any tag will do. Will try my luck at the Waiuku parts world
Your waterpump is in that general area. I'd start by looking at the thermo housing, might need silicone re-applied or a new thermo seal, hopefully sorts it for ya!
Ross started following Coolant leak from rh timing cover?
Ross started following Auckland Tag
So sexy, what camera you take that on?
Will be very interested to see what figures you achieve, what mods do you currently have on your bg5? Or what do you plan to run? I myself run the zerosports 87 Ecu for rev c bg5 manual, however I haven't been able to find out what parameters have been changed over the stock ecu
Ross started following Zero Sports Sequential Controller Assistance
Ooooooh where did you get it?? Been wanting one for my car
Ross started following Fuji heavy industries tag
Puzzle time, My fuji industries tag has been removed at some point for reasons unknown to me, possibly removed when the old owner had it re-registered? I don't know. Any ideas where I can get a new one stamped out, if at all? Or know of a wrecked bg5 that I can pinch it off Cheers.
Installed them on my gtb, loosened the nut that torques the steering rack onto the steering wheel pillar, Gives you a bit more wiggle room to get the bushing in. Use a paint pen to get the alignment spot on if you drop the rack to low
Ross started following What have you done to your car today?
Installed whiteline steering rack bushes and a new headunit today
Cheers for your advice, managed to find the leak, was the radiator petcock leaking under pressure, little bit of silicone on the thread solved it
Had the same issue with my gtb, my issue was the plastic petcock at the bottom of the radiator, very miniscule amount of coolant but frustrating! bit of silicone on the thread fixed it
I drive a legacy bg5 and i need some help identifying what issues my car has. Issue 1 is that on a cold start I have noticed I get alot of what is possibly steam out of my exhaust? No noticeable smell like burnt oil or coolant just happens every morning in what I think is an excessive amount. I have a catless primary down pipe also a small but consistent loss of coolant, haven't been able to locate the leak and am unsure whether these could be related. Another issue I've been having is this persistent smell of oil or over fueling when on primary boost, have a replacement turbo to drop just haven't had the time to install yet, I suspect it's the primary leaking oil because I have oil within the tmic but could it also be a leaking injector causing the smell? Or the white smoke on cold start due to running rich? Just done a 5000kms service and my oil was pretty darn black, Anyone know where I can get them serviced? Any input is appreciated, cheers
Who's Online 0 Members, 0 Anonymous, 11 Guests (See full list)
