johnny5
V7 Sti coughing and sputtering on WOT
The car has developed a sputtering effect on WOT from what I tested out on open roads its more likely to happen when plating my foot down in fifth or 6th gear to overtake or even if i chop down to 4th to pass from 80kmh to 110kph.
Now if I just give the car some boot through the gears once its warm and up to temp it can be fine some times not playing up at all but after a little while of driving on the motorway it will start sputtering under load.
It seems like a miss but its only intermittent and only on WOT in higher gears
Research from Nasioc suggested AFR sensor troubles but I wouldn't have a clue I might just order and change it to be safe soon but your guys thoughts would be great Im also leaning towards new coil packs maybe .
The Plugs are about 3000kms old I went with BKR7EIX this time around
Front cam sensor has been changed 1000kms ago
no CEL's have flashed while this has happened but I will be pulling codes and doing logs this Saturday with Pappu
Share this post
Link to post
Coils or afm at a guess. Plenty of v7s in auck swap some parts up.
Share this post
Link to post
I'll see what parts Pappu or one of the boys have but its what I'm leaning to next but surely that would have made a cel flash bro
Share this post
Link to post
Coils don't light CEL that frequently for some reason. Dunno about Subies specifically, but on some cars (yes, OBDII equipped) you can completely disconnect the coil and not cause a CEL.
Share this post
Link to post
Not necessarily afm doesnt always throw cel and no idea how misfire cel is thrown.
Share this post
Link to post
I'll test this tomorrow I have pulled them to do a test before but can't remember
Share this post
Link to post
Dont think so as they have a built in ignitor. Well thats what ive read i have no ae knowledge.
Share this post
Link to post
What boost control system you running ? standard oem solenoid or aftermarket ?
Share this post
Link to post
 Fastfour said:
Have got a set of coils from a ver7 STi sitting on my shelf currently
Could very well be coming to see you I think bro
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
