if you do end up going with a hx35 let me know as my up pipe/ downpipe will work.
getting somthing like that made does cost mega bucks as evo said unless you can fab it yourself
only issue is the part tellin others to try it .
your more then welcome to do it to your own vehicle, but telling others to try it and have fun with no idea what it is doing ....... do you see no issue .
a 2000 b4 legacy is det prone on nz fuel to start with
sorry have edited it
if you understand it so well then what is the af raitos at wot? you don\'t even know what boost its running currently.
buggering around with a factory twin turbo system is asking for some busted ringlands
as above 315kw @4600 rmp with a blown headgasket
thats were they stopped.
boost came on early and thats with the bigger hx40
was very fun to drive ! gotasuby knows he tuned it
im trying to find the dyno thread there\'s a pic of the plot there
As far is im aware, im 90% sure.
The ones i did were for link controlled cars so just the 10% uncertain as to weather polarity matters with a standard ecu
hx35 twin scroll will handle enough for what you\'ll want to do and come on boost alot earlier.
youll want the sump, pickup and the windage tray (pretty sure you can use the non ts windage tray)
if your doing cams def do at least springs
prob wouldn\'t bother with a bigger oil pump tho
my last setup was very similar and was a very fun car! which made 315kw @4600 with a blown headgasket
fyi DONT do this
free boosting / doing stuped shit is a sure fire way of killing your engine .
without extra fuel to compensate for added air = massive mess
V9 sti is were the hubs changed to 5/114 and had different mounting from what i have been told.
but with the exception of the wrx or the same era (my?? dunno ) which stayed 5/100
i figure that would cause some bad things with oil pressure.
there would be ways around it which would cost more$$
even the cross drilled cranks use the same bearing so i see no issue with oem
you can mount them on the block using existing blanks in the casting.
I put pressure at the back of block next to the bell housing.
and the temp were lachlan suggested
from what i can see you have it correct .
from filter teed off to the front of both rails and then the back teed intothe side of reg and then bottom of reg to return
like this except your rails are in parallel
there deff v1/4 rails . the oem injector pictured has the v1/4 pintle on it.
the sards you have may be suitable for v5/6 rails as there slightly different (or is that what the collar is for?)
when I got my 50 motorsport injectors it stated they were a v1/4 replacement but they werent, they did fit in v5/6 rails tho .
worth looking into
ae? dont replace the factory lines .
if they can support 300+ kw they will work on a standard wrx.
post a pic up of how the bits are hooked up and how fuel lines are hooked up.
do you have the reg on the return to the tank? are you certain that the fuel lines are around the correct way?
