Help needed ASAP
nt_a_foz
If all the dash warning lights are glowing (oil pressure and charge etc) then thats a sure sign the regulator is scrood....however it wouldnt explain the electronic fail thats occuring even with the engine not running.
If you use a test light, use one with an incandescent bulb, not a LED. The LED ones don't draw enough current and can make bad fuses appear ok. Been there, done that, confused camper.
oh ok thought you were taking the piss.. used a test light as well as pulling out and checking visaully..
Right so just put a fresh battery on and started car...
Voltage across battery is 12.3-12.4 odd volts then when you turn lights etc on it drops to round 11.7 odd volts.
Swapped alternators and got the same readings
We then unplugged power to alternator and still got the same reading
SOOOO would appear teh signal to alternator is failing???
Not really helping us get any closer to the mass electrical fault
i know thats why its pissing me right off haha
As far as i know everything was working when we got the car....
We only used the rev d long block rest was from original motor..
As far as i can see everything is back as it should be...
No doubt at all its something silly..
So at currently the airbag light is on, rev and odo dont work, light showing where gearlever is selected not wroking also, heater fan, dash light dimmer, temp gauge and i think thats all off the top of my head
heheehe man it so sounds like a fuse :)
either Alt or ecu
does the alternator get its signal straight from battery or from ECU ?????
other thing I would check is check fuse continuity using a test light on the back of the fuse box, thinking of bad/corroded contacts
Well well well..
The route of the problem has been discovered...
When we originally couldnt get the car to start (wrong cam, crank pullys) my flatty pulled apart behind the fuse box under steering wheel.
He then "put back together" but apparently didnt do the bolt upholding the plug in place.
Which in term left dodgy connections or no connections..
Soon as he tightened that up (We were doing a mass double check everything tonight) it worked fine...
So is all sweet..
;D
