Volt Gauge
smokn4
if you go to the battery this would remove voltage drop caused by other things (depending were you wired it)
but really, just the ACC from the ignition will do sweet :D
will also turn off when the cars not on, so wont drain the battery
-smurff
I get around 0.5-1 volt drop at my lighter socket. Fine for a volt gauge but a major pain in the ass for when im using my inverter as its low battery alarm goes off at 11v instead of 10.5v (which doesnt take very long once the engine is off)
 smokn4 said:
how about wiring to the petrol pump???
just thinking wouldn't it give you a idea of what the current voltage its using under load?? if the pumps running 100%
or am i thinking with my ass ::)
:D :D
voltage will drop a bit, but if you had a Amp gauge you will see the difference in full load and half load.
-smurff
