Squeaking clutch on my B4
jabz
Recently my clutch is letting out quite a skeaking noise as I depress the clutch pedal. Can be heard from the engine bay, louder than what can be heard in the cabin. I don't have any issues with the clutch/gearbox performance. So what should I get looked at? What is likely the issue?
thanks
Guest boostin
Try lubing the tip of the slave cylinder pushrod where it contacts the clutch fork. Use some heavy duty stuff like lithium spray grease, not CRC, WD40 etc.
  • 5 weeks later...
ok my mate has just put a new motor in his b4 and has got the same problem only it really squeeks and when the clutch is pressed it makes a weird scuffing noise as well and when released just a squeak what could be going on here ill lube the pushord on the slave cylinder im thinking maybe somehow the fork popped out when he put it together
mine squeaks. i did some searching around and found it was quite common with Subarus, will try and get it fixed at some stage.
The scuffing noise seems to be normal with a new clutch until it beds itself in. Have had it on the last 3 clutches ive done. Mine squeeks/creaks when you release the clutch but thats actually the dashboard inside the car flexing where the pedal mounts to it.
Did you cable tie it in or something? I love how rangi you are buddy
Nah the dash on the GT30 has a different design to what ive seen on the GT. Theres no supports on the bit the clutch pedal bolts into so it flexes under strain :P
