vf8 boost
danz-rs
 BC5RA said:
16psi is about the limit for a VF8 I've seen them run at up to 18psi but you would be just pushing hot air.
Damn my one stops at 0.7bar of boost (VF8) it'll go down after 5000rpm to about 0.5. But 2nd gear pull - I LOVE IT!!! Would dying plugs play a part in that too? wanting to do a change but i'm after platinum/iridium plugs. My wastegate actuator and the rod bit are a bit rusted too, would that do anything?
 RS.YES']
Whats your setup?
Have you chipped it or increased boost? a VF8 running on a stock ecu will be around 10psi.
  • 2 months later...
