Seat belt jams
Caleb 895/1000
if your meaning that the rell has jammed, making the belt not retract, then yes, you should be able to fix it.
Mine got stuck on the reel when i tugged it a bit too hard. To fix it i just took the plastic trim panel and released the bar holding the reel in the locked position while turning the reel.
Now it works. it sounds more difficult then it is, but its pretty easy once you see it.
