BH5 Alignment specs
Anybody have some nice well-proven alignment specs for a BH5 GTB? No track work just road driving (often enthusiastic), not a fan of understeer so thinking maybe -1° front camber, but I don't want to chew out tyres too fast either - I run more camber than that on the MX5 with no funny wear, but different cars do different things to tyres. Also toe settings - slight toe-in front, zero toe rear sound right?
Are castor and rear camber adjustable too on these?
Check out Whitelines website, they have alignment specs that works really well aparantly, I wanted to run -1 on my Leggy at the front but the guys who done the work on it said it'l bugger my tyres real quick, but not too sure really.
I'm running 0mm toe front and rear and -1 degree of camber on the front.
They seem to be wearing fairly well and understeer doesn't seem too much of a problem.
Cheers, sounds good then - I'll check out the whiteline site too.
For comparison I get pretty even wear from the MX5 with close to zero toe, -1.1 deg front and -1.5 deg rear camber. Also has 4.5+ deg castor which is a lot more than a Legacy at about 3 deg. It is a much lighter car though with higher profile tyres and obviously being rwd doesn't work the fronts as hard as a Sub.
