will a v4 sti tmic fit on a bg5?
Jonnysnow
Are you keeping it in Twin Turbo?
The core is essentially the same. The inlet possibly swaps between the two. From memory I think you need the STI mounts aswell. Just spend you cash on some sand blasting and then pink spray paint and make a stencil from cardboard to achieve the same end result :P
so it is essentially the same intercooler then? i would have thought the sti one was fatter/more efficient. if its not then i dont care about pink spraypaint haha
oh and yes it will be staying twin turbo for now.
Yeah, same core, only difference is the bling, and the 34mm BOV outlet (over the GTB's 19mm BOV). And as koom mentioned, the bracket is different too. Singe turbo is shorter.
There's only disparity with the intercoolers once you get to V7 and up.
