Differential Subaru service tool anybody know where to get?
 turborunner said:
since you dont use the 13mm tool you want to sell it?
so have you undone the plug yet or what!!!! nobody i know ever uses the "special" tool for diffs. a power bar is the best tool. it just doesnt look special as its a normal tool.
its like a retard looks pretty special to you but to his mum hes normal
  • 3 weeks later...
Just done my diff got the filler plug undone but could not undo drain plug my 1/2" powerbar with extension bar and light taps with rubber mellit and still no budge also started to eat away at the bolt as its on way too tight. so just syphoned the old oil out got about 800mls and syphoned the new motul 90pa diff oil in. feels different. noticing more push from the rearend when boosting. might get a garage next time to undo the drain bolt so it can be drained properly.
put a piece of pipe on it... when i do them on the ground i put a bottle jack under the end of my power bar to stop it slipping out of the hole. ;D
