Link LEM G3 wiring with 4 single coils
Stoffa
Ok the G3 has 4 ignition drives, I want to use 4 seprate coils rather than my current wasted spark set up.
Looking at sample wiring options in the G3 wiring instructions they normally use 2 chanels to fire wasted spark and the remaining 2 chanels for fuel pump relay and Engine fan relay.
If I use one ignition drive for each coil, how/where would I wire in the fuel pump and fan relays?
Talk to optical he just went to 4 seperate gdb? coils i think on his g3. I was there assisting him when he fired it up.
He's away at superlap atm back monday i think.
You will need 2 spare auxailiarys to run the fuel pump and electic fans.
more often then not you will have a couple left over, but it does vary with setups.
LS1 coils are the most powerful coils you can get without going to expencive CDI setup.
LS1 coils are also the same/very similar as MSD coils, just not painted red and not as expencive
Stock wasted spark is fine depending on the setup,
Munkvy who runs stock 4x coils on his RS has a bit of ingniton issues that has limited how much boost and power we could have got out of it previously.
You would have spoken to Aaron our tuner.
We do always reccomend going for the best/cost effective ingniton setup as the last thing you want is ingnition issues limiting how your car performs.
