how to remove heater core
turborunner
I've removed the steel bar just got the black boxes left cant figure how to get them out. undone two bolts at top of the centre box where the heatercore lives and all the little screws on that box but still wont budge and the aircon box the top part looks like it holding the centre one so remove the little screw on that and cant get the top off that box.
do i have to release the air con gas and remove the air con aswell dont want to.
nah they are 2 separate boxes, you should be able to leave the aircon in place, and remove the central heater box
once you remove the screws the rubber grommets on the firewall will hold the pipes. pull. :)
check up behind the aircon, there may be one last screw
If you remove the blower fan it may give you enough room to move the A/C evaporator box to the left and squeeze the heater box out.
I know its possible on BG Legacys, but not on BH. You may have to degas the A/C system.
 turborunner said:
how do you degas the a/c? if i end up needing to remove the ac box as well
I believe that technically needs to be done to NZ environmental legislation (EPA), probably best left to a automotive /refrigerant tech??
ratchet tryed again to take box off i cut some of the tabs on the ac that is preventing the heater box coming off but still no go must have more at the back that i cant see or get.
i was told its partially blocked and is restricting flow is it possible to flush the crap out while its still attached or does the core need to be replaced might have to put it back together and just bypass the bloody thing.
I've been around these things for years, and never successfully cleaned one. Replacement is the only way.
And yes, the A/C system must be serviced by a qualified A/C tech. Normally a degas/regas is around $100. A lot cheaper than any fines!!
