rust on battery tray
kingersman
nope it wont fail (unless it so bad your battery sitting on your wheel and as long as the hold down strap is tight ) as how would they see that it is rusty
I would clean with baking soda and hot water,then just hot water,then sand,then paint with a rust kill,then a galv based undercoat,then a topcoat (or if u can get a CRC Galv paint in a close colour then this )
i had rust on my battery tray from leaked acid, ended up getting the whole tray removed while i had my engine out cause i was worried bout rust been underneath it.
but i had my battery mounted in the boot so i didnt need it.
as drfvdr said kill the rust asap or it will spread.
get some baking soda and hot water and tip it on the rust / acid first.
it washes the acid off and will stop it corroding any further
