New heater core
Durty-Sanchez
Fuel pump relay doesn't initiate sometimes ... its fairly old so I figure it's just getting stuck (comes right after a few minutes). New one will do the trick - unless it's the alarm relays!
In cabin fan relay is also gone (I assume). The main power wire to the fan went some years back somewhere between the relay and the fan (so under the dash somewhere). I ran a new wire and it was sweet for a year but eventually it stopped again. Power gets to the relay but not out of it so it's my main suspect... could be running too much current or shorting out somewhere, potentially I need to add some resistance to the fan if it's drawing too much current or find where the power wire's shorting out.
Stoked about not needing the de-gas!
