Speak installation
here is a how-to we did for speaker spacer installation for our MR2, I know its an MR2 but the same technic would apply to any speaker and door hole that does not match up, hope it helps
ok, I was an idiot and dropped a pair of linemans pliers off the door jam and onto my beloved infinity speaker!
so we had to buy some new speakers and tweeters for the front. we measured the doors and asked dimensions from the seller and we somehow still got it wrong, the seller does not have the correct size we need, so off to the garage we go :)
we like to do as many things our selfs as possible so we figured, we need to make some sort of spacers, I know you can buy them but this post is for anyone who wants to do it them selfs, I think ours is better than what you can buy, but thats obviously just our opinion.
as you can see we bought them too big
so we bought some supplies from placemakers and bought some 5 mill cover sheet, liquid nails, silicon, the foam came from the speaker packaging
dummy fit the speaker in the door and mark of scribe on the speaker which way is going to be "up" and left and right, this way it will always be aligned correctly
so off we go, we cut a circle
now we need to measure and cut the inner circle so we have a donut
use a template me made to scribe a nice circle
now we have it laid out we need to cut it
pilot hole
cutting
inside done
now for the outside
done
now a quick sand to round off the edges
dummy fit
need to mark holes for the screws
Mark the sides of the spacer, because when you put on the foam you are not going to be able to see the markings on the top.
drill screw holes
dummy fit
more dummy fit
one more
we cut some foam from the packaging
take the cut spacer and mark the inside
cut
now the inside
there is some thicker foam that came with the speakers as well, repeat this step with the thick foam too
dummy fit
now we glue the thinner ring
fit it
press it for a couple of minutes
now the thicker ring
we use the silicon
some tape on the door for protection and make sure nothing touches metal
maybe a little of the foam inside for extra
dummy fit
hook up the crossovers
and speaker wires
fitment time
this setup uses the stock holes
so the woofers are done, we could end this now but we thought to finish it, we are almost done!
run the wires up to the tweeter from the crossover
attach the tweeter to the bracket and screw it in
tweeter bracket
put things back together and you are done
note, we did dummy fit the door panel once or twice before we did the final install of the panel
I am sure you can do this easier, like buying spacers and things but we like to do things ourselfs
now its time for the reward
hope this helps other do-it-yourselfers
lol ya, we try to do how-to's as complete as we can lol lol
if you thought this was a lot of pics you should see the one we did on how to paint a car in your own garage lol lol
