Heater Fan Resistor replacement
sirwrx
Hi Guys
I need your help.
The heater fan only works on 4 in my 87 leone RX coupe.
I have tried to find the resistor that controls the heater fan speed with no luck so far.
Does anyone have any pictures of what this resistor looks like. I know it is up under the dash on the passengers side.
Just want to avoid pulling to much of the heater out if I don't have to.
I have already tried to swap the fan motor over so I know it's not attached to this.
I have just scored a donor car over the weekend and the fan works on all speed in it so I want to swap them over.
Thanks in advance
Garrick
 sirwrx said:
Hi Guys
I need your help.
Thanks in advance
Garrick
IIRC its in the side of the fan unit up under the passengers foot area. two screws & a plug to remove and on the resistor pack its self there is a single contact to resolder there is one that normally comes unsoldered.
Should be resonably obvious, its will have a plug on it and two screws.
When you get it out Post a pic of it if you get stuck with what to solder
