hose bits/breathers
sultan
Guest boostcut
 sultan said:
does any one know where i can get a hose T piece or similar that has two 14mm nipples and one 20mm nipple?
is for vac hose so doesn't need to handle liquids. or perhaps hose reducers?
go to repco, they have plastic joiners, tees, all for cheap as.
i have a catch can/breather at current, which has the two breathers off the heads going to it. i'm planning on plumbing the crank case breather into one of the hoses that goes to one of the head breathers and sharing it with . it's a 20mm outlet on the crank case but i was going to down size it to 14mm and T it into the 14mm hose. Is this a good idea, or would this be overworking that one 14mm hose?
or is the crank case breather so vital that i should not only give it its own dedicated hose, but also not downsize it to 14mm too?
Guest boostcut
going from 20mm to 14mm is effectively halving the flow. i would have a single hose from the crank case and heads, with the heads being joined near the tank somewhere..
Guest boostcut
my thread tape holds 10,000 psi on an excavator for years.. so it should hold 120psi for a couple minutes
the problem with the anerobic liquid sealants is the excess that falls into the oil galleries. you dont know its gone in until something fucks out.
