A Work In Progress
It is, not many photos same out, although i was driving it instead of pushing it haha. once i get a wide angle it should be better as i can have the pole shorter.
still dont have a ball head so the camera is fixed, hence the crappy framing
you were driving it! gee, dont be so lazy and push it :P
you get the ballhead on there and a wide angle, she will be beautiful!
what cups are you using? hows the suction on them?
your inspiring me to get on with making mine at last lol
-smurff
I'm to weak to push the car while the wheels are turned, and they end up going straight.
Um suction cups are dual ones for holding glass, they for good, but you need a flat surface to get all 4 sucked on, I only just 2 at a time.
ahhh, i noticed in the second pick on of them wasnt sucking. that explains it.
might try revise your setup, see if its easy to do with four single cups.
-smurff
