94 rs not firing
me and a mate brought a 94 rs legacy with blowen engine, since then we have fitted a semi closed deck single turbo. go to start it, its not wanting to fire, has new spark plugs, but its almost like its not cranking over fast enough to spark.
basicly im after ideas for what it could be.
if u need more information to get a beter idea, just ask.
cheers
 rs_with_a_kick said:
yes, was twin turbo, and will fit a single turbo ecu and c what happens
Have you chucked a single turbo motor into a TT and then hoped the TT ECU would run it?
You know that the wiring between a TT ECU and a single ECU is significantly different?
