Why 2x antenna connectors?
albaru
I thought it was similar to the nissan diversity antenna system, they also run two leads?
Haven't seen one of those Kenwood GX-77 units in years, even 5+ years ago the CD players stopped working in them. Was yours still working Al? If so that's quite legendary. I guess it finally became redundant when classic hits moved from 90.0 to 90.1
What did you replace it with?
The wierd thing is that both the car and the receiver have 2x leads - male and female. I originally thought maybe the 2nd female connector may have been a sheilded control wire for the up/down motor of antenna so I put 12v down it to check. A fuse blew. Who knew that would happen?! Classic case of overthinking.
The GX-77 played CDs but only on shop recorded ones. Home-burnt didn't get read. Tape and radio still worked fine. Now replaced with a 2nd hand unit ex Stoffa. It's an Apine CDA 9847 and works good. Repco didn't have a suitable Subaru connector so I did a top-class butcher job with 12-14 bullet connectors!
