Injectors
k thanks for that, how do i tell what size the wrx sti ones are. do i have to get them flow tested or should there be somthing written/in-graved on them?
my mate has the same ECU in his STI... so i guess ill have to take it to a Subaru place and thel b able to tell me if itz tuneable or not aye?
So does your one even plug into your car? Cause there's three plugs on the V3/4 STI's and 4-plugs on the older Legacy's. The wiring is substantially different and the sensors used aren't interchangable. So you either have one thats exactly the same as his and won't work on your car unless you change alot of things and re-wire the plugs, or you have a different version of the ECU as to what he has and you're more likely to find information on the ECU on the internet via the manufacturer.
this topic comes up all the time. some people seem to get away with just sticking larger injectors on the engine, but none of the 'tech' guys here recommend it. its a rough-as-guts approach and we have no sympathy when you have problems :D
also, in before koom gets cranky with j00s :P :P
there are lots of threads regarding injectors. do a search and read up some
Guest S T  E Y E
yes i still needa check which ecu i have on mine with yellow injectors and prange maf haha.... runs fine and gets good as fuel economy however...ill check today haha
